Check out my Tranny fluid! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2008, 12:56 PM   #1 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Ive had the XLE for several months and have slowly noticed the transmission getting worse.
Decided today was the day to start the drain and fills (plan on doing 3-4) and this is what I found!
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 11-01-2008, 03:55 PM   #2 (permalink)
View Uzziah's Photo Gallery
That's pretty disgusting, but not as bad as I've seen. Good for you for doing it.
However, instead of doing three or four fills, you could do your own flush now that you changed the filter. I post pretty heavily over at Benzworld, one of the members did his (after dropping the pan so he could change the filter) by unscrewing the cooler line from the radiator (he used the pressure side so he could put a tube on the line and direct it to a measured container). Then he fired up the car and ran out a quart or so, shut off the engine (obviously a two-person process), then added that amount in fresh fluid. Then he repeated the process until he got a quart of fresh fluid out at the cooler line Then he buttoned it back up, set the level and checked for leaks, that way he safely changed as much of the fluid as possible, including the stuff normally trapped in the valve body, cooler and of course, the torque converter.
Take care and enjoy the ride,
Greg
Uzziah is offline   Reply With Quote
Old 11-02-2008, 07:09 AM   #3 (permalink)
Do not buy from
View Zviator's Photo Gallery
U didn't check those things when u got the car ?
Zviator is offline   Reply With Quote
Old 11-02-2008, 08:20 AM   #4 (permalink)
It wasn't black when I got the car. See first post "have slowly noticed the transmission getting worse".
After driving the car after the drain/fill and stop slip Trans-X, I havent noticed any improvement.
Old 11-03-2008, 02:10 PM   #5 (permalink)
bootcamper's Avatar
View bootcamper's Photo Gallery
Hi xtremeskier,
I have the same issue with my 99 v6 LE. My transmission is doing fine. But, my oil is way too dirty. What did you do and and what would you recommend I do?
What tranny oil and filter did you buy?
Did you replace yourself?
Please advise me? Thx.
-M
Camry 99, V6 LE Black w/ kits & bronze alloys
bootcamper is offline   Reply With Quote
Old 11-04-2008, 11:34 AM   #6 (permalink)
Bdub215's Avatar
Gameroom cash: $315565
View Bdub215's Photo Gallery
guess i'll pose my question here. my trans is slipping but my fluid which i changed 2 months ago still looks and smells the same way the day i put it in. think its fried clutches?
"xtremeskier97It wasn't black when I got the car. See first post "have slowly noticed the transmission getting worse".
After driving the car after the drain/fill and stop slip Trans-X, I havent noticed any improvement"
and whats that stop slip stuff and where can i get it?
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 11-04-2008, 05:56 PM   #7 (permalink)
Originally Posted by bootcamper View Post
Hi xtremeskier,
-M
I was using Penzoil tranny fluid. I havent changed the filter on the V6, just the I4, but I got them from PartsAmerica.com (same as AdvancedAuto Parts). I just drained it at the drain plug (allen socket) and filled back up. I was planning on doing this a few times, but with the other problems im having with this tranny, Im not sure Ill go further with it yet.
If I were you, I would drain and fill 3-4 times, replacing the filter and cleaning the magnets on the last fill.
Not sure, maybe someone else can help here?
It's called Trans-X, but I cant recommend it because I havent seen any improvements. There are several different options, Lucas Oil being the most expensive that Ive seen. I got it at Wal-Mart.
