1992 camry doors will not remain locked - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2008, 07:26 PM   #1 (permalink)
View suz92's Photo Gallery
Question 1992 camry doors will not remain locked
I have a 92 camry automatic LE. While driving today all 4 doors automatically unlocked. Tried the door lock button to relock them but it did not work. The doors would immediately unlock again. Hoping this will not turn out to be a costly problem. Would appreciate any help.
Thanks,
Susan
suz92 is offline   Reply With Quote
Old 11-01-2008, 07:37 PM   #2 (permalink)
just a nobody
Have you check to make sure all the door are closed properly? Does the vehicle have keyless entry?
N.E.O.
Old 11-01-2008, 07:53 PM   #3 (permalink)
Yes all the doors are closed properly and there's no keyless entry.
Old 11-01-2008, 08:15 PM   #4 (permalink)
just a nobody
Have you check the door lock switch on the right side to see if it is sticking?
The most common cause to a problem like yours is one of the door courtesy light switch may not be fully depressed with the door closed. Did you happen to notice if the interior light coming on and off when the door locks were acting up?
Other possible cause could be the door unlock switches in the door latches, or a wiring problem.
N.E.O.
Old 11-01-2008, 08:21 PM   #5 (permalink)
340,000 miles+......
sk8ersublime's Avatar
View sk8ersublime's Photo Gallery
sometimes i get this with my keyless...but it usually goes away if i lock the car from the outside instead of the button
http://www.cardomain.com/ride/2915998
340,000+
sk8ersublime is offline   Reply With Quote
Old 11-01-2008, 08:23 PM   #6 (permalink)
just a nobody
Were you making a turn when that happens?
N.E.O.
Old 11-01-2008, 08:58 PM   #7 (permalink)
Camryv6xle's Avatar
View Camryv6xle's Photo Gallery
was it happening while driving or after you got out and took the key out, sometimes when i take the key out of the ignition, the ignitions still stays in place as though there was a key in there and itll go ding ding ding ding ding and and locks wont lock so i gotta just press it in with my finger to reset it
http://i89.photobucket.com/albums/k205/gunit2049/0108091104-00-1.jpg
Camryv6xle is offline   Reply With Quote
