my car wants to stall after starting
Hey all, 94 Camry LE Auto with 159,000 miles.
I've got two separate starting problems, I'm wondering if anyone could shed some light on either. They've both started within the last month or two, when it's started getting cooler out, though I don't know if that is related or not.
#1, sometimes when I start the car, I hear a...like jamming metal mechanical noise from under the hood. It's sort of hard to describe...it's usually right after I let off the key because the engine is started. When the sharp jamming sound comes, the rpm goes from normal quick down to like 400, like something caught or jammed, then goes back up to the normal rpm without me interfering. Happens a couple times a week, doesn't affect starting, is just sort of...I don't know. It hasn't caused any problems yet, maybe it will in the future.
#2, sometimes when I start the car, the idle rpm goes down incredibly low, and the car acts like it wants to stall, but never quite gets there. Instead the car just vibrates as the engine rpm flutters slightly like vroom VROOM vroom VROOM vroom VROOM. I hope you know what I mean. Very low rpm to slightly higher back to very low, to slightly higher. Usually I give it a little gas, and it just goes back to idling normally. This is not at all limited to when the car was cold, in fact the first time it hapenned, the car was completely warmed up. But it happens when cold and when warm.
If anyone could shed any light on this, it'd be great. None of these are really earth shattering problems, I'm just curious if there's anything I can or should be doing to fix them.
Thanks!
1994 Camry LE 5SFE
160,000 miles[12/2/08]
