Anyone ever seen a "shoulder bolt" on the timing tensioner pulley? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-08-2008, 06:50 AM   #1 (permalink)
View blueapple's Photo Gallery
I had a discussion with a co-worker, and he insisted that there exists such an arrangement. Where the tensioner pulley (Spring tensioned) is never really tightened down, and allowed for self adjustment. I have never seen it. and it sounds like a source for noise... All Toyota I've worked on had a non-self adjustable tensioner with a straight bolt
Has anyone ever seen something like that on a 5SFE?
Picture of a shoulder bolt:
http://www.suburbanbolt.com/images/-0030.jpg
blueapple is offline   Reply With Quote
Old 11-08-2008, 07:29 AM   #2 (permalink)
just a nobody
Did he say how it would maintain the proper tension of the timing belt? The spring that the engine has isn't strong enough to do that!
N.E.O.
Old 11-08-2008, 08:14 AM   #3 (permalink)
I have no clue how the detail is going to work out. I think the spring could be strong enough on increasing RPM, but I don't know if sudden drop in RPM could make it skip or not. I don't believe Toyota ever used that design, but I'm just curious, since there are so many variations of 5SFE (most of what I know is just electrical stuff)
Old 11-08-2008, 09:40 AM   #4 (permalink)
just a nobody
The factory spring isn't strong enough, the first time you hit the accelerator the timing belt will skip if the bolt for the tensioner is not tighten down. Just try turning the can or crank with the tensioner loose and it will happen.
N.E.O.
Old 11-08-2008, 11:34 AM   #5 (permalink)
View toyomoho's Photo Gallery
Never heard of this free moving pulley arrangement on this engine.
Other makes of engines also lock down the pulley.
There are setups that allow movement of the tensioner pulley but doubt under this application.
Old 11-08-2008, 01:09 PM   #6 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
going by the concept, it would make sense to not have the tensioner bolt snugged down to allow stretch on the belt. but on toyotas, the way the belt is made it should never stretch so the tensioner shouldnt need to be tightened to pull in slack.
Old 11-08-2008, 02:29 PM   #7 (permalink)
I'm not sure about never stretching. I know the 20v 4age had hydraulic tensioner driven by engine oil pressure.
