Thank you for the follow up N.E.O. I'm gonna use the one I have. I'm just waiting for the upper idler to get here, likely tomorrow, then I can finish the job.
Not to get too far off topic, but for the life of me, I can't see which of the bolts under there is the pivot for the power steering pump.
I thought it was the topmost one, right under the plastic cover, and spent an hour trying to get a wrench on it. I finally gave up and just removed the adjuster bolt entirely, then levered the pump up with prybars. That bolt, if it's the right one, is only slightly easier to see/access with the timing cover off.
