93 camry xle v6 overheating - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-08-2008, 04:49 PM   #1 (permalink)
View davemac2's Photo Gallery
This car has driven me nuts for the past two years. I've gone thru 3 rads, and now it is overheating after a 40 min highway drive. It won't overheat under street driving conditions. The rad has been replaced since the old one appeared to leak, but this has made no difference. It seems to have lost coolant, but I'm not sure if it is overflowing out of the reservoir or somewhere else. I test drove it last nite again and as I was pulling back into the garage from a 40min highway run, it just started to overheat. I looked the rad area and engine over and could not find any coolant leaking whatsover. It also did not seem have lost much coolant if any. The area around the waterpump appears completely dry as well. The exhaust has no coolant smell at all. The car starts up just fine in the morning after sitting, so it doesn't seem like coolant is seeping into the cylinders. I did a block test this morning and it was negative. I retried that test twice after running the engine for 40mins at idle to get it hot, and again negative. I also pulled all 6 plugs and they all appear dry and exactly the same. The coolant in the system has been completely clean as well as the engine oil. Ie. no cross contamination. The symptom points to a blown head gasket, but the testing so far says no. I'm going to try a compression/pressure test to see if I can blow air from the cylinders back into the cooling system and check cylinder compression. Besides that, I'm at a loss as to what else I can do to narrow this one down.
Some ques:
1. I guess this could also be a corroded or slipping water pump not circulating enough water with the cooling system gettng overwelmed, but I assume this is not too common?
2. Has anyone else had overheating symptoms similar to mine on this V6 3zvfe engine that turned out to be something besides the head gasket?
3. One thing I need to check again is whether the hydraulic rad fan is coming on full speed when the overheating begins. After 45-1hr of highway driving, does this fan usually come on at high speed with moderate ambient temps? Can anybody comment on their experience with that? I would think at highway speeds, there would be enough air flow to cool the rad without the fan at all under normal operation.
I am hesitant to pull the head(s) unless I can determine for sure it is a head gasket. Too much bloody work! Someone mentioned on an older thread about pulling the thermostat to have a look at the water pump impeller since you can see the outer part of it from the thermo housing. Is that true?
Any help is appreciated.
dave mc
davemac2 is offline   Reply With Quote
Old 11-08-2008, 10:07 PM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862510
View BamZipPow's Photo Gallery
With all that you've put into it so far...I'd go ahead and pull the water pump then...
BamZipPow is online now   Reply With Quote
Old 11-08-2008, 11:47 PM   #3 (permalink)
engineer in training
Gameroom cash: $145055
The water pump is a decent DIY job ont he 3vz, nothing in particular is a pain its just a tiring job.
If the problem is not in the water pump it is possible the system has a clog on one of the many cooling passages on the block, you could try a total system flush and run some mineral deposit remover through to try and break up and large chunks of rust or deposit that can develop. It is a cast iron block after all.
Old 11-09-2008, 02:18 AM   #4 (permalink)
Camryv6xle's Avatar
View Camryv6xle's Photo Gallery
i had all those symtptoms and all i needed to do was replace the waterpump. but while i was at it i changed the belts and everthing too. i say from my very similar experience to change the water pump. i have a 1mz fe btw, dont know if that would make a difference in this case but ill throw that out there. good luck with this.
http://i89.photobucket.com/albums/k205/gunit2049/0108091104-00-1.jpg
Camryv6xle is offline   Reply With Quote
The Following User Says Thank You to Camryv6xle For This Useful Post:
Greg123 (01-02-2012)
Old 11-09-2008, 07:39 PM   #5 (permalink)
I took the waterpump off today. It looks almost brand new. No corrosion, and the impeller seems to be attached to the shaft solidly. I'll replace the pump and timing belt anyways as well as the thermostat, but now I'm at a loss since the block test was negative for exhaust gases. The only other thing I'm going to check for is a collapsing lower hose at high RPM when it is starting to overheat, and maybe do a chemical flush on the block.
Otherwise, I guess I will need to take it to someone else to get a 2nd opinion.
dave mc
Old 11-09-2008, 08:35 PM   #6 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Man I have the exact same problems with my 3vz, but I AM losing coolant sometimes because it's boiling out of the overflow. This happens about once a month to me, and I have to refill the coolant and bleed the system.
Im thinking mine IS the water pump, but I havent done all the tests you have.\
I also question whether or not the hydraulic fan is actually working like it should. Id love to just convert to electric like Eye8 has.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 11-10-2008, 11:51 AM   #7 (permalink)
For me though, the fact that it is overheating on the highway eliminates the fan entirely since the rad should be getting plenty of air on its own. I bought some chemical cleaner yesterday, so I'll give that a shot next.
dave mc
Old 11-10-2008, 12:18 PM   #8 (permalink)
View toyomoho's Photo Gallery
You did a chemical test of the coolant for exhaust gases and this was neg?
Does running the heater full on help lower the temps?
Does the car have the bottom plastic air skirt installed below the radiator.
Plugged CAT.
http://en.allexperts.com/q/Toyota-Re.../f_4103504.htm
Old 11-10-2008, 06:04 PM   #9 (permalink)
Yes, 3X, negative
A bit.
yes, but for the camry, I don't think that can really cause an overheat per say since that rad has direct cooling thru the grill.
Interesting, I'll have to look into that one, but I doubt it. The car seems to have lots of power.
I'm not sure i f I trust this new cheapie rad I bought off Ebay. I'm wondering if its cooling capacity is bad. I'm about ready to throw in the towel on this one and get a shop to take a shot at it. It almost left me stranded today. The only thing I may do before that is try another rad and replace both coolant caps. Then again, I think I've reached my limit both in frustration and time.
dave mc
Old 11-10-2008, 08:20 PM   #10 (permalink)
View llcoolpass's Photo Gallery
experitise
****O K one thing I know very well isthe cooling system failure modes on this car, so davemac2, listen up, to answer one of your questions.
secondly, you tested the comrpession and see no signs of head gasket failure.
ok, let's move on.
you have new radiator, but old hoses.
you notice the problem more on the highway.
question1: what does the dash temp gauge read?
question2: is the a/c on?
question3: what is the ambient temp in your driving range?
question4: what is the vac pressure at idle [to check for clog catalytic converter as toyomobo rightly asked]?
question5: how fast is it that you are going on highway?
question6: when warmed up, if you rev the engine to 2000 in neutral with parking brake on, does the cooling fan come on high speed from a slow speed? if not, check the temp gauge see if it starts going up. also, at the same time, if it starts going up, do not rev engine anymore, but turn off engine for a few. Then, come back here and post....
question7: did you bleed the cooling system properly [with the heater on full hot full fan, and fill with 50:50 or 40:60 coolant:distilled water]?
fact: being on the highway does NOT preclude car overheating. under some conditions it can still happen , folks, on the car in question i promise i'm not lieing.
so if you answer those questions, I can take you to the next step ....
1993 Lexus ES 300 [completely stock] -- 5-speed Manual V-6 3VZ-FE -- Curb Weight 3,570 lbs; Mileage 152,000 -- 0-60mph http://www.youtube.com/watch?v=ygwUh1MZRLM
llcoolpass is offline   Reply With Quote
Old 11-10-2008, 08:49 PM   #11 (permalink)
Where do you get the head gasket leak detector and how much does it cost?
Old 11-10-2008, 08:58 PM   #12 (permalink)
BamZipPow's Avatar
I was gonna question about the hoses as well but I would think if you replaced the radiator 3 times the hoses would've been a cheaper choice.
Old 11-10-2008, 09:56 PM   #13 (permalink)
xtremeskier, there is a cooling system pressure check tool that's usually 30 dollars.
the rest is leakdown testing using comrpessed air source and building pressure into the combustion chamber.
or in simple easy way is compression check and vacuum check [less accurate ways but helpful] and checking spark plugs and combustion chamber after engine is turned off to see if coolant is therein withdrawn by the pressure difference due to cooling and so on.
Old 11-11-2008, 12:21 AM   #14 (permalink)
http://www.amazon.com/Universal-Test.../dp/B000I17Z68 $25
dave mc
Old 11-11-2008, 12:56 AM   #15 (permalink)
just a nobody
Sounds like your radiator caps are letting the coolant out but not letting it back into the cooling system. Have you check the hose in the coolant reservoir to make sure it is flowing both ways?
N.E.O.
