1995 Camry 2.2 engine convert to Japanese 2.0 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-08-2008, 10:34 PM   #1 (permalink)
View bartsing's Photo Gallery
USA 1995 Camry 2.2 engine convert to Japanese 2.0
I recently experienced my engine locking up on me because of very low oil remaining in the engine because of a bad oil change at Walmart.
I bought a used 1993 2.0 Japanese engine to replace the 1995 2.2 engine.
On the first night the starter went out.
Is this a normal?
I have read all of these difference websites saying that it's okay to replace with the 2.0. Why the complication?
Help, help, help... Please..
This is an expensive process...
bartsing is offline   Reply With Quote
Old 11-08-2008, 10:38 PM   #2 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
Is this a normal?
2Liter is the 3s-fe not the 5s-fe ... might not work bro
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
Old 11-08-2008, 11:54 PM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Was it the starter for the 3sfe or did you use the starter from your 5sfe?
Kep
Old 11-09-2008, 10:23 AM   #4 (permalink)
it was the starter that originally came with the 5sfe
Old 11-09-2008, 10:24 AM   #5 (permalink)
it was the starter that came with the 1995 5sfe
Old 11-09-2008, 10:41 AM   #6 (permalink)
The womaneater!!!!!!!!!!!
samarai912's Avatar
View samarai912's Photo Gallery
same tranny? is the fly wheel on those exactly the same size? and starter placement? you'd better make sure before your starter eats a fly wheel.
-guese I'm not much help.....
GF:"samarai I want to marry you." Me:"Uhhhh..I made a mistake.I only love my car"
Camry gen4 1mz turbocharged @ ? bar(updated)
.http://www.cardomain.com/ride/3029563
samarai912 is offline   Reply With Quote
Old 11-09-2008, 09:42 PM   #7 (permalink)
Kep
Kep's Avatar
I would say your first chore would be to verrify that the two use the same starter. If the 3SFE takes more torque than the 5SFE does, it may have over stressed the 5SFE's starter. Samari912's points are also good. Incorrect alignment might also stress out the starter or damage the "flywheel".
Kep
