Originally Posted by Hajoca
Are you sure that is for a V6??
The listing refers to the I4 engines.
This is the kit
SUPERCHARGER TUNER STAGE PACKAGE
REQUIRES PERFORMANCE HEADERS TO BE INSTALLED.
Everything you need to setup a supercharger to be functional is included.
Designed to bolt up to the 6G72 V6 (six cylinder) 3.0L engine.:hypnosis:
System has had zero engine failures to date.
Kit will work with auto, manual or tip-tronic.
Boosts from low RPM’s with NO LAG Time normally associated with turbos
Professional installation required.
Tuners Package come with:
RIPP SDS (Supercharger Drive System) 6061 Aluminum CNC design and fabricated
RIPP/Vortech V5 G-Trim Supercharger
RIPP By Pass Valve
All 6061 aluminum piping
Four Ply silicon hose (Gloss Black, Red, or Blue)
All hardware and clamps included
2 Part 20 page Illustrated Instructions
Easy 12-15 hour install
VORTECH V-5 G-TRIM Specs:
Fits engines up to 575 horsepower
Maximum airflow: 800 CFM
Maximum boost pressure: 25 PSI
Absolute maximum impeller speed: 65,000 RPM
Adiabatic efficiency: 73%
8.93 Wide, 9.72 Tall (not including bracket), 5.82 Deep (not including input shaft)
