The pdf file technical manual says this:
putting vacuum on the system;
With a .35mm gauge on the throttle stop:
- the ohms is .5 kilo ohms or less
With a .70mm gauge on the throttle stop:
- the ohms is infinity
And to set, using a .54mm gauge on the throttle stop:
- Says when the gauge deflects, this is where to set the tps.
Heres my problem, at what point of deflection?
Because it will go from .2 kilo-ohms on up to 20-40 kilo-ohms till it goes infinite.
I can set the .35mm step just at .5 kilo ohms and anywhere in between.
I can set the TPS with .54mm step about .2k to 10-40k before infinity.
Which gauge setup should i use and where exactly (#) should it be set?
With my .35mm set at .18 kilo -ohms, and .54mm set around 40k to infinity, I get the final idle at 700 rpms.
If I turn the ac on, it bumps a bit, then back to 700 rpms. When I turn the ac off, it goes to 950 rpms, then gradually back down to 700 rpms.
Throttle response is decent, a lot better than it was(the .35 mm use to be .61 kilo ohms, which was too high).(now .18 kilo-ohms)
Anyone with some knowledge on this, clue me in?
Setting TPS is a pain, and i want to get it right and forget it finally.
thanks for some help.
UPDATE: -------------------------------------------------->
I used the specs at .50mm for the 1mzfe engine from advance auto parts website.
It states .50mm <2.3kilo ohms
managed to set it at 1.8 kilo ohms.
Annoyingly, you can breath on the tps, and it will change resistance.
Took me hrs to set it just right.
Also, the stop screw I adjusted to just touch the stop point, while the car was running
(this allowed for the blade to be fully closed, as it is not fully closed when the car is not running.)
Oddly enough, the idle was running at 700 rpms again. So since I had each mm adjustment in specs, I turned the stop screw to bump the idle up a little, but not much.
When I test drove, it had some very good throttle response. No idle dive, until I got back to my apartment. I switched from reverse to drive really fast, and so it dived, but not too bad(650 rpms).
specs:
.35 mm (.19 kilo ohms)
.508 mm (1.8 kilo ohms)
.54 mm( idk, since book only says when the ohm meter deflects, your guess is as good as mine, and so i didnt bother to check this time.)
.70 mm (infinity)
All other spec checks were in order.
Why in the world didn't toyota make a self adjusting TPS?
btw, did I do this right?
Robert
