Front Passenger Door wont lock. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2008, 11:34 AM   #1 (permalink)
Okami's Avatar
View Okami's Photo Gallery
Hi I have a 1994 Camry and my Front Passenger door won't lock or unlock unless I manually do it. This problem kinda just came out of the blue and I was wondering what it could be. Something is obviously not connecting in the door handle panel or something. How much would this cost to get fixed? I wouldnt think it would be expensive but what do I know?
Thanks for future help
Okami is offline   Reply With Quote
Old 11-11-2008, 11:51 AM   #2 (permalink)
O-Dark-30
frenum49's Avatar
View frenum49's Photo Gallery
Could be something as simple as a bad connection. Or you may need a new power lock actuator. Check eBay or the web for the part. Won't cost much if you put it in yourself.
frenum49 is offline   Reply With Quote
Old 11-11-2008, 12:45 PM   #3 (permalink)
Noob
View gladis's Photo Gallery
Check out the DIY on how to take the door panel apart, if you want to do it yourself. This seems to be a common problem with Toyotas, as both my Camry and the Sienna has that problem. The mechanic will charge way too much to fix the simple problem.
I've been too lazy to tackle it though, I might try for it over winter break.
1996 Toyota Camry LE 2.2 - 139xxx 162xxx
2000 Toyota Sienna XLE 3.0 - 82xxx 104xxx
08/08 08/11
gladis is offline   Reply With Quote
Old 11-11-2008, 08:10 PM   #4 (permalink)
Okami's Avatar
Thanks thats probably what I need to do.
Old 11-12-2008, 10:55 PM   #5 (permalink)
View proftomda's Photo Gallery
USA
To be clear, niether the switch on the drivers door or the switch on the passenger door will actuate the passenger door lock, is that correct? If neither switch will actuate the door lock on the passenger side, i would suspect the door control relay box under the dash. It could also be wiring but if the door panel hasnt ever been removed or the car never in a accident in the drivers door area, the odds are slim that the wiring is damaged.
proftomda is offline   Reply With Quote
Old 02-07-2010, 02:17 PM   #6 (permalink)
View Kaline's Photo Gallery
Okami: My 1999 Camry had the same issue on the passenger front door. The door lock actuator gave out. This component is bolted to the door latch, which is difficult to replace. I bought a new actuator and confirmed the old one is bad (new actuator moves when plugged into the car's wiring harness), but I have not been able to get the latch assembly out yet (real pain the butt)!
1999 Camry LE (2.2L I4), auto, Antique Sage Pearl with Sage cloth interior, 160K+ Miles, Michelin Radial X Tires, Alpine CDE-103BT headunit, Otherwise 100% stock. Owned since August 2002
1999 Camry LE (2.2L I4), auto, Black with Oak cloth interior, 168K+ Miles, 100% stock. Sold June 2010
Kaline is offline   Reply With Quote
Old 02-07-2010, 03:05 PM   #7 (permalink)
TOYODA KAMURI
the_professional's Avatar
View the_professional's Photo Gallery
i doubt okami is coming back.
i love my 1992 Toyota Camry LE 2.2L 5S-FE - 73K
9005 NIGHT GUIDE LOW BEAMS|FOG LAMPS|PIONEER HU&AUDIO|KEYLESS ENTRY
1995 Acura Legend LS KA7 3.2L C32A - 87K
SADLY, SHE HAS MUCH MORE MODS...
the_professional is offline   Reply With Quote
