0 Ohm means not resistance, and O.L. means open circuit, those are kind of two extreme.
Here are the specs for some of the parts for the ignition system:
Ignition coil:
Primary cold: 0.36 - 0.55 Ohm; hot: 0.45 - 0.65 Ohm;
Secondary cold: 9.0 - 15.4 k Ohm; hot 11.4 - 18.1 k Ohm;
Pickup coil: cold 135 - 220 Ohm; hot 175 - 255 Ohm;
Crank sensor: cold: 985 - 1600 Ohm; hot 1265 - 1890 Ohm.
Check each items cold resistance and see where you are at; might want to check some of them at the ECM too, just to be sure that it is the same or close to the same values.
BTW, don't worry about testing with the old distributor, I had my head crossed there.
N.E.O.
