Not sure if it is worth the hassle. That's your decision alone. You can probably drop a new engine in it for $1500-$2000 with labor, but then you need to fix the door (new door?) too. So after all that, you are in the range of what this Camry would go for used, ~$2.5K in my area anyways. It may or may not turn out to be a bargain. Now if you can do the work yourself, you may potentially salvage the existing engine and just redo the head gaskets and resurface the heads for maybe $300-$800 depending upon the condition of the heads. This is assuming though that the block or its bearings haven't been ruined by coolant contamination in the oil. You would have to take a quick sample of the oil in the pan from the drain plug to see if coolant is present. Besides the engine though, you have no way of knowing if the transmission is in good shape unless you put the engine back together. (do they still have all the parts?) Then there is the condition of the struts and suspension components. Does the A/C work well or is it broken too? I'd say buying a non-running vehicle like this is a kind of risky. I would try to put the engine back together first before I even bought it just to see how everything else is.
dave mc
