lol......Use a Spark Plug socket?
http://images.google.com/images?q=sp...=1&sa=N&tab=wi
Here's a quick one for you:
1. Order from a place like
www.sparkplugs.com You enter Year, Model, Make and they'll give you appropriately matched brands. You should be fine with Denso or NGK.
2. Buy a sparkplug socket and Anti seize compound.
3. Consider changing out Spark plug wires, cap, and rotor.
4. Use an extension on a socket wrench for the spark plug socket.
5. Counter clock wise.
6.Back in with the new... You can double check the gap if you like, but they made the plug appropriately already. Dab a tiny bit of the anti seize on the threads.
7 IMportant: use only the extension with the socket so you can get the plugs in easier.
8 Tighten to torque specs (I don't know them) or I would just do it to just firm with the wrench.
