^^ definitely check the wiring, you don't want that to short circuit if something is touching.
Other than that, did you recently add anything electrical? Or messed around with the electrical system? Also does your digital clock reset also? If you clock resets, then I would check your fuse box, or even the battery terminals for corrosion or loose connection!
92 Camry 4 cyl 5 Spd
390,000km, Retrofited Projectors + 6000k HID, 2500k Fogs, SRI, K-Sport Coilovers, TRD Rear Sway Bar, GEN4 Ralco Short Shifter, Alpine 7" IVA-D900, 2 x 10" MTX / MTX 900W Amp
the clock doesn't reset, and i didn't change or add anything electrical of any kind
maybe i should point out that i'm a speed freak and i drive my car like i stole it, always drag racing... does that have anything to do with it?
The clock memory may now be on other fuses rather then combined as in the past. Such as Cig, Panel and Dome.
Suggest you remove the radio and test the power wires. One should have power when the ign switch is on, the other always. Wires might be Gray for ign power, Blue/Yellow for constant power.
ok thanks for the wire colors that should help
thanks again
This exact thing happened to me about 3 months ago. It turned out to be a bad battery. The car would start just fine but for some reason the memory resets would disappear. A new battery fixed it right up.
