camry 2001 : clock/lighter do not work - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-15-2008, 03:18 PM   #1 (permalink)
View webwesen's Photo Gallery
i am trying to find the right fuse to replace.
I have found rather cryptic fuse map for Camry 2002 on the net and hope that this is similar to 2001:
which fuse is it? thanks!
webwesen is offline   Reply With Quote
Old 11-15-2008, 03:39 PM   #2 (permalink)
just a nobody
Try fuse 'CIG'; cigarette lighter.
N.E.O.
Old 11-15-2008, 05:38 PM   #3 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862710
View BamZipPow's Photo Gallery
In my T100 truck...I had 2 fuses to check/replace. Dome was one and the other was the CIG.
BamZipPow is online now   Reply With Quote
Old 11-22-2008, 10:12 AM   #4 (permalink)
View John5516's Photo Gallery
Ya same in my cam, i blew the dome fuse and the clock and lighter did not work. As you change the cig one, try the dome one also
98 Camry CE:
K-Sport Coilovers, Drop In K&N Filter, Brembo Rotors and Pads, Ipod Plug and Play, Mod-Express 4300k H4-L Kit
For Sale:
K-Sport Coilovers!
John5516 is offline   Reply With Quote
Old 11-22-2008, 12:56 PM   #5 (permalink)
290,000KMs And Countin'
View alexg2008's Photo Gallery
Canada
I blew that same fuse in my '97 too. Thrice. The door locking when the car is turned off won't work, nor will the windows. And the dome, cig lighter, clock won't either. I don't remember what the fuse is numbered, but its in the fuse box in the engine compartment near the front rows. It's a 7.5A fuse, if i remember correctly. Good Luck!
alexg2008 is offline   Reply With Quote
Old 11-22-2008, 09:59 PM   #6 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
N.E.O.
x2
5 Lug Corolla WHAT?
Old 11-23-2008, 12:04 AM   #7 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
Try pulling the coin box out left of the steering wheel. Should be the bottom one on the right. 15A
Dave's is offline   Reply With Quote
Old 11-23-2008, 12:19 PM   #8 (permalink)
BamZipPow's Avatar
That's the 1997 Camry XLE fuse map on the back of the coin box door. To remove the door, just open it and pull straight up.
Old 11-23-2008, 02:02 PM   #9 (permalink)
bye
bye's Avatar
View bye's Photo Gallery
i had the same problem for a couple of months after i installed a new deck with a amp+sub. i replaced the fuse that was for the cig lighter+clock+power windows and it always kept blowing after a couple of hours then i had the whole fuse box replaced along with all new fuses for every spot and the problem went away =D
bye is offline   Reply With Quote
Old 11-23-2008, 11:11 PM   #10 (permalink)
The Connoisseur
CharmCityES's Avatar
replace the cigaratte lighter fuse labeled "CIG" on the fusebox diagram....the dome lights, cig lighter and clock all are on the same circuit on the gen 4 camry, and that fuse is quite commonly blown
The "Executive Sedan"
