Short in speaker wire? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2008, 06:23 PM   #1 (permalink)
Newbie
deezeejoey's Avatar
View deezeejoey's Photo Gallery
So i was driving down the highway yesterday and my back right speaker started to make this static noise.... I change a bunch of settings and it didn't fix anything.
I turned my Head unit OFF and it was still making the noise.
The only thing different is that it's cold outside. You think the change from hot to cold has made some wires come loose?
deezeejoey is offline   Reply With Quote
Old 11-18-2008, 07:54 PM   #2 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
Is it possible that you blew your speaker?
EDIT: Sorry, didn't see that you said it does it when it is off.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 11-18-2008, 08:01 PM   #3 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862710
View BamZipPow's Photo Gallery
Are you sure something didn't fall in there? Are you sure it's coming from yer speaker?
BamZipPow is online now   Reply With Quote
Old 11-18-2008, 10:09 PM   #4 (permalink)
Newbie
deezeejoey's Avatar
Yeah, it's def the speaker making the noise. But i didn't think that a blown speaker would make static noise when it's OFF?
Old 11-18-2008, 10:49 PM   #5 (permalink)
View toyomoho's Photo Gallery
The Radio No 1 fuse is for radio memory, the Radio No 2 fuse actually powers the system.
Try removing the Radio No 2 fuse and determine if the speaker quiets.
If the radio DOES NOT have an anti-theft system were if the power fails a code needs to be entered then you can try pulling both fuses.
Old 11-19-2008, 12:07 AM   #6 (permalink)
BamZipPow's Avatar
The only way the speaker could make sound is current going to it. Check to see if the speaker wires have voltage going to it.
