Removing Valve on 97 6v CAM - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-19-2008, 02:32 PM   #1 (permalink)
muminiasty's Avatar
View muminiasty's Photo Gallery
I would like to ask any of you who would be taking your valve out if you could post some pictures. I'm still a noob here but I learned some of the stuff from this forum about my v6 CAMRY. I wanted to remove the valve and replace the gasket because I'm getting minimal leak on the front. Also one of the bolts that hold the gasket poped on me and it needs to be replaced. Where can I get bolts like this. I went to the closest AutoZone and they didn't't have it, Please Help.
Thanks
muminiasty is offline   Reply With Quote
Old 11-19-2008, 02:49 PM   #2 (permalink)
muminiasty's Avatar
Before I remove the valve. I'm guessing I should disconnect the battery?? Also should I drain the oil before I open the valve???
Old 11-19-2008, 02:52 PM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
do you mean valve cover? if your tryin to just remove the valve cover then just disconnect the wires to the plugs, remove the plastic sheild and remove, coil packs and unbolt it. it may take a little love to pop it off. and what do you mean "poped" the bolt snapped? if so ull have to get a kit or shop to remove the snapped bolt and then just use one of the other bolts to find another. also a haynes manual, which can be bought at an auto parts store, will be LOADS of help with little jobs like this.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 11-19-2008, 03:13 PM   #4 (permalink)
muminiasty's Avatar
I took the bolt out and only end of it snapped. Do you think PeP Boys may have it?? Well I will try to go to couple of places today and ask them. I'm sorry I meant valve cover, I found Sticky with valve removal. It helped a lot . Also Do I need to drain oil before taking valve cover off? My guess is yes.
Old 11-19-2008, 06:08 PM   #5 (permalink)
View toyomoho's Photo Gallery
Try the Autozone website, they have self help repair info with drawings for valve cover removal.
Your engine is a 1MZ-FE
Old 11-19-2008, 07:24 PM   #6 (permalink)
muminiasty's Avatar
I found something but I'm wondering about this step
Drain and recycle the engine coolant. Is that needed to do. So I don't have to drain oil when opening the valve??
Old 11-19-2008, 08:32 PM   #7 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
No, you dont have to drain the oil before taking it off, just let the car sit a bit before doing it, so all the oil drains back down to the pan.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 11-19-2008, 09:02 PM   #8 (permalink)
just a nobody
Which valve cover are you resealing? From the way you are describing you must be doing the front valve cover. The valve cover bolts are dealer only item, if I remember correctly they are the spring washer type.
Where do you see the oil leaking from? If it is around the front backing plate area, it maybe the cam seal.
N.E.O.
