wiggle and vibrate. need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2008, 09:43 PM   #1 (permalink)
View angel_rolla's Photo Gallery
3rd Generation wiggle and vibrate. need help
hello TN,
i have search the internet on what's the possible cause of steering wheel vibrating at highspeed (60-70mph) and wiggle (sometimes) at low speed (15-30mph) but didn't find a solid answer. so i thought i'll post it in here since lot of us own a camry.
i have had this problem probably about a year ago, and it was worst. it's like all the plastic parts inside the car start to get lose. so about a month ago i decided to change some old worn out parts for the car. list below.
- front axle
- polyurethane control arm bushing
- ball joints
- swaybar links
- tires have about 80% rotated
- brake job
- wheel alignment
- gen 4 engine dogbone mount
after the parts have all replaced. i still feel the vibration and wiggle though it's not as bad as before. are there any of you have this problem before?? this is my daily driver and i am trying to take car of it since it was given to me by my parents and it was my first car. it's just getting annoying and it's scare me sometimes especially at freeway.
BTW, do you guys know if the tire pressure have something to do with it?
angel_rolla is offline   Reply With Quote
Old 11-22-2008, 06:14 PM   #2 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $349353
View BMR's Photo Gallery
Had similar problem on my Camry. Did many of the same things you did. Wound up being my wheel bearings. Here's a link to the DIY thread I made for the rears; Link. And here's the DIY thread for the fronts: Link.
Edit:
Oh, and I doubt tire pressure could have something to do with it. A bad tire, perhaps.
BMR is online now   Reply With Quote
Old 11-22-2008, 07:21 PM   #3 (permalink)
just a nobody
BMR is correct. Tire maybe, tire pressure no. If you are feeling the vibration in your steering, rotate the tires front to back, if the vibration is gone from the steering then your front tires were causing the problem.
N.E.O.
Old 11-27-2008, 01:34 PM   #4 (permalink)
View maclugnut's Photo Gallery
hubs
Worn rear axle hubs gave me the same results as tread separation. Replaced one and my problem was fixed. Jack the rear end and inspect with wheel assy on hub. Does it move side to side?
maclugnut is offline   Reply With Quote
Old 11-28-2008, 02:10 PM   #5 (permalink)
Gameroom cash: $303255
Have the tires been rebalanced? Sometimes we forget the simple things.
Mike
Old 11-28-2008, 04:59 PM   #6 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $284080
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
tie rod end???
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 11-28-2008, 09:12 PM   #7 (permalink)
^ i'll do that first since i have new parts (tie rod end & inner tie rod). i'll update for the result. thanks guys
