Exhaust Issues
The camry now sounds like a V8... when its only a 2.2L 5SFE.
i noticed a month ago a slighter louder engine noise but it wasnt much of a difference. Two days ago, at 75% throttle, all of a sudden the engine is deeper & with a growl. Same thing occurs no matter if the engine is hot or cold. It is most noticable when it accelerates from the 2000-4500 RPM range. Maybe the cold contracted and the heat expanded some parts? it was about 28 degrees out. I checked the under body for the exhaust, seems to be nothing under there. But, when the engine is reved, and even at idle, you hear a much louder noise right on the engine. Im guessing the intake manifold is loose? Since the sound i heard before was barely noticable a month a goand now it is pretty loud. No engine problems, no dash lights. Please help! How do i go about this? If it is the exhaust manifold, where do i tighten/check the manifold?
Thanks in advance!
i love my 1992 Toyota Camry LE 2.2L 5S-FE - 73K
9005 NIGHT GUIDE LOW BEAMS|FOG LAMPS|PIONEER HU&AUDIO|KEYLESS ENTRY
1995 Acura Legend LS KA7 3.2L C32A - 87K
SADLY, SHE HAS MUCH MORE MODS...
Reason: typos.
