No reverse lights when put into reverse 1993 Manual Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-24-2008, 04:45 PM   #1 (permalink)
Justin '93 Camry Owner
View AmericanAirFan's Photo Gallery
3rd Generation No reverse lights when put into reverse 1993 Manual Camry
Hey guys, one thing wrong with my car that has been wrong since I got it is the that when I put the car in reverse my reverse lights don't come on. I've heard that a suspect could be the wiring harness is chafed where the trunk lid is where the wires go through but I've checked there and there are no chafed wires and is actually incredibly very intact. All other lights work, i.e. brake lights and blinker/caution lights but the reverse lights don't work. Any ideas?
AmericanAirFan is offline   Reply With Quote
Old 11-24-2008, 06:19 PM   #2 (permalink)
nooB nooB noo
View Larzzzz's Photo Gallery
Back up light switch. Find it, unplug it and if it has 2 wires, then short them. If it has 1 wire, ground it. See if the lights come on. The switch could be operated either by the shift linkage or a cam inside the transmission....Is it bolted to the transmission, or bolted into the transmission??????
'06 DCLB Indigo,Scangauge II, Redline tuning hood struts, map light mod, trailer plug mod, LED bed lights Thule X-sporter racks. Aux. back up lights.
Larzzzz is offline   Reply With Quote
Old 11-24-2008, 09:55 PM   #3 (permalink)
_
Gameroom cash: $221635
View uuuuu's Photo Gallery
Do the lights on your instrument gauge work (P R N D 2 L)? If not, it may be a faulty Neutral Safety Switch.
uuuuu is offline   Reply With Quote
Old 11-24-2008, 10:22 PM   #4 (permalink)
My car is actually a standard transmission so I don't have that on the dash but my dash lights work just fine. I don't know where I would go to find the reverse switch since it would be somewhere underneath the works of the car I'm not very good with cars but if you pointed me in the right direction with the help of my dad I can figure it out..
Old 11-25-2008, 03:54 AM   #5 (permalink)
nooB nooB noo
You need a manual for that car. A lot of us weren't good with cars at first. If that's FWD then everything will be under the hood. The switch will be near where the shift cable attaches to the tranny. It's really not that difficult. You can do it.
Old 11-25-2008, 01:30 PM   #6 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862710
View BamZipPow's Photo Gallery
It looks to be on top of the transmission on the driver's side.
http://www.toyodiy.com/parts/p_U_199....html?hl=84210
BamZipPow is online now   Reply With Quote
Old 11-25-2008, 01:32 PM   #7 (permalink)
BamZipPow's Avatar
Okay...are you sure yer reverse light bulbs are good?
