The bolt pattern is correct, but I'm finding info that suggests the offset on those wheels may be 55mm which is too high for your Solara so you'd need spacers.
Also, the center bore for the hub won't be the same. I don't know the center bore on the Accord, but the Camry/Solara center bore is 60.1mm If the Accord is smaller, they won't work. If the Accord hub is bigger, you'd need centering rings.
Edit: I'm seeing info that suggests the center bore for the Accord wheel is 64mm.
