^ Well, I'm not 100% sure if you need to swap the wiring harness. The V6 has hydrolic fans, and the I4 is electric. I know when 2WickedToyz here on the foum did the EXACT opposide of you, he HAD to swap the dash harness. The issue was is the hydrolic fan's had an extra relay in the dash, that had 1 extra 2 wire connector under the dash that connected to the engine harness. Your doing the opposite, so I am not sure if you'd have an issue using the same harness that is currently in it.
As for the engine wire harness, leave it all attached to the engine. Just unplug it at the ECU, putt it though the wire harness, and unhook it all from the engine bay.
5 Lug Corolla WHAT?
