no spark, no check engine light at all. ?????? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-28-2008, 06:23 PM   #1 (permalink)
View hfmt93's Photo Gallery
I still can not get my car to start after an engine install.
It has no spark.
The thing i do not get is why the check engine light will not come on at all. It doesn't even come on when you first turn the key before start.
I thought that because it doesn't light up the problem might be the ecu is not getting power. I tested the ecu and it is getting power.
Is there a way to see if the check engine light is burnt out?
i found that the igt to e1 terminals are not getting any voltage across
also, the igf to e1 with switch on or turning over.
Please help, i am having trouble and cant seem to figure it out.
hfmt93 is offline   Reply With Quote
