Rear Tail Light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-28-2008, 07:56 PM   #1 (permalink)
View macs's Photo Gallery
Question Rear Tail Light
I just purchased a 98 camry and the tail light dash light is on and the blinkers dont work but everything else does, any help would be appreciated.
macs is offline   Reply With Quote
Old 11-29-2008, 07:03 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
When you put the turn signals on do the lights come on but just not blink?
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 11-29-2008, 10:14 AM   #3 (permalink)
cruisn76's Avatar
View cruisn76's Photo Gallery
A common issue is the third brake light. It is high mount one inside the rear windshield.
If changing that doesn't help, you might wanna take check every bulb and socket for corrosion and clean it off.
92 Camry 4 cyl 5 Spd
390,000km, Retrofited Projectors + 6000k HID, 2500k Fogs, SRI, K-Sport Coilovers, TRD Rear Sway Bar, GEN4 Ralco Short Shifter, Alpine 7" IVA-D900, 2 x 10" MTX / MTX 900W Amp
cruisn76 is offline   Reply With Quote
Old 11-29-2008, 12:15 PM   #4 (permalink)
The turn signal lights dont come on but they do with the flashers
Old 11-30-2008, 09:35 AM   #5 (permalink)
From my manual there is a separate fuse for turn signals (7.5amp) and hazard (10amp). I'd check the fuse first. The same flasher is used for both turn signals and hazard with an input from turn signal switch and hazard switch. I guess the flasher could be bad and after the fuse that would be your least cost try. After that I'd look at the switch. Use a test light to confirm power transmission to components.
