abs sensor change - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-28-2008, 09:24 PM   #1 (permalink)
View ricelake's Photo Gallery
abs sensor change
new owner 97 for my son code 39 rear sensor replace, from what I can find they break when removed or frozen and won't be removed any tips on removal of sensor would be greatly appreciated thanks in advance for the help! what a great forum
ricelake is offline   Reply With Quote
Old 11-28-2008, 09:33 PM   #2 (permalink)
just a nobody
Four or six?
There isn't any specific way to remove the sensor; however, sometimes, it may help when it is warmed up, like after you have driven the car for a little bit before removing the sensor.
N.E.O.
Old 11-29-2008, 11:10 AM   #3 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $349353
View BMR's Photo Gallery
I don't know how the rears are, but I just replaced the front left on my Cam. The old one was so corroded in place, the back end snapped off when I pulled on it. Then I used a needle nose pliers to pull the guts out of it; basically a boatload of fine copper wire windings. Then the outer shell came out by cutting thru the outer plastic body that was still stuck firmly in the hole. Once it was out, getting the new one back in was easy. I suppose you could use some PB Blaster or something like that, but I still doubt the sensor would come out in one piece. Since it's bad anyway, why bother trying?... Just go directly to the nukes.
The one thing I can say about the rears on my '92 is this: The sensing face of the sensor goes inside the bearing cartridge where it reads the toothed ring. This area is sealed off to keep debris out of the open (non-sealed) wheel bearings that live inside. Be careful not to let junk fall inside when demolishing the sensor. It might get into the bearings. The safest way would be to pull the bearing cartridge out beforehand.
BTW NEO, I owe you an apology. A while back I disagreed with you when you said there was a small magnet in the end of these sensors. While I was cutting out the old one, the end of the new one snapped itself onto my razor knife; magnetically, that is. Sonovagon!!
BMR is online now   Reply With Quote
Old 11-30-2008, 09:27 AM   #4 (permalink)
just a nobody
BMR, don't think anything of it!
N.E.O.
