1995 Camry Headlight Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-29-2008, 06:37 PM   #1 (permalink)
View mboyle's Photo Gallery
Low beam headlight went out. Replaced the low-beam bulb and it still doesn't work. Other side headlight is fine and both high beams are ok. Any idea what might cause this problem? Since the other light works ok didn't check the fuse - should I? Any other ideas would be appreciated.
Thanks!
mboyle is offline   Reply With Quote
Old 11-30-2008, 09:17 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Each side has a dedicated fuse for HB/LB. There is one relay for both sides. I would look to defective new bulb (switch to other side to see if it works there), bad/corroded connector or broken wire. Use a test light to confirm power at connector.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 11-30-2008, 09:37 AM   #3 (permalink)
just a nobody
I agree it may be a bad bulb. And depending on what kind of bulb it is, hope you didn't touch the glass part of it, it will shorten the life of the bulb.
N.E.O.
