I have a camry that died while driving 30mph, and never ran again. I checked the codes code 12 no signal to ecu from ne or g. So I put a rebuilt distributor. I still have the same problem code 12. I have to fix my car soon and i dont have money for an ecu. Can anybody please help me. I dont know how to check for an open circuit or short between my disrtibutor and ecu. any input is EXTREMELY APPRECIATED
also when i turn on the key the speedometer goes about halfway up about 70 and slowly comes back down, the car has only been siting up about three months
The ECM is behind the glove box, if there is no signal there then you have to trace the wiring to figure where if there is an open.
No sure what is wrong with the speedo, poor connection or wiring maybe?
Beside replacing the distributor, what else have you done? Did you check all the ground connections to make sure that they are clean and tight? What is the general condition of the car? Got any picture?
automatic except california, rotor spins timing is perfect there is NO SIGNAL TO ECU FROM DISTRIBUTOR does anyone know why?
new echo is right, you'll have to trace open or short circuit in G & Ne signals and the STA circuit. I can only give you my 95's circuit, the 94 may be slightly different so you should get a circuit diagram. On the ECU there is are three connectors, 26 pin, 16 pin, 22 pin. The wiring for G and Ne is on the 26 pin connector. G+/G- is #18yellow/17black, Ne+/Ne- is #4red/5blue. This is from the ECU side so you'll have to match up the wiring harness connectors. The STA circuit gets its signal from the starter. Its purpose is a richer start mixture. This circuit goes to the 22 pin connector #11black/white. I'm not sure if a bad STA circuit will give a no spark or not, but it is part of the Code 12. As for the ECU, if you need yours checked out or fixed here is a great company that will rebuild yours for about $160: http://avproecm.com/index.htm
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
