A dealer or a wrecking yard would be the best bet, doubt very much it is something you can get from a parts store. It is more of a noise filter, you can probably put a 15A fuse in place temporarily until you can get a new one, probably need a fuse holder for that. As far as why it went bad, there maybe a short and if you put a higher Amp fuse in place of the correct rated one, it will take out the next weaker link. If the 15A fuse blows, I would check the wiring harness by the left trunk hinge, which is very common for broken wires that may short togther.
N.E.O.
