Groaning/roaring noise when braking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-01-2008, 12:37 PM   #1 (permalink)
View balingwire's Photo Gallery
4th Generation Groaning/roaring noise when braking
My '99 Camry produces a groaning/roaring noise when braking from higher speeds (40 mph or above?) or braking hard. The noise is very loud in the cabin. Otherwise, the car handles good, it's quiet, and when it was aligned, the shop did not point out any problems. I bought the car from the original owner when it had about 180K miles on it. Now it has nearly 184K miles. It's made this noise the whole time that I've had it. Is it a brake problem or a wheel bearing, since it only makes the noise when the front end is under a braking load? Is it something else? I've done a search and found that someone had a similar problem, but there was no followup on what the problem was. Thanks.
balingwire is offline   Reply With Quote
Old 12-02-2008, 09:27 AM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
How much brake pad material do you have?
Is rotor in good condition or you have hard spots?
(warped rotors feel and sound different from what you describe)
Since it only happens at high speeds or hard braking (nose dives) did you check your front suspension and struts?
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
