Replacing engine coolant temperature switch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-02-2008, 07:05 AM   #1 (permalink)
View 94CamryMan's Photo Gallery
I was wondering if the coolant had to be drained first when replacing the engine coolant temperature switch on a 94 camry?
94CamryMan is offline   Reply With Quote
Old 12-02-2008, 09:06 AM   #2 (permalink)
just a nobody
Just a little bit, or if you are fast enough, take the radiator cap off to release the pressure then put it back on, and just put a towel underneath it and swap it out.
N.E.O.
Old 12-02-2008, 02:43 PM   #3 (permalink)
Gameroom cash: $303255
94CamryMan,
I was just wondering if you took any readings with a digital volt/ohmeter before replacing the ECT switch, and if so, what those readings were and at what temperatures? Thanks for responding.
Mike
