Timing Belt Pulley - Difficulty Removing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-02-2008, 03:15 PM   #1 (permalink)
Canyon Killer
View ekopel's Photo Gallery
4th Generation Timing Belt Pulley - Difficulty Removing
Hey boys,
So I am trying to pull my heads off to make sure I didn't fuck them up at all when I threw a rod.
My first problem, surprisingly, is that I can not seem to get the timing belt pulley off. I have seen that you can put two bolts into the rear cover, I saw one guy using two crescent wrenches, and i bought a 15" wrench, biggest one I could find, and am using a breaker bar. The thing just does not want to come off! I soaked it in penetrating fluid also, so it has been sitting for almost 24 hours being penetrated.
ANY ideaS?
P.S. 1MZFE - and motor is still in engine bay for now.
LOTS OF GOOD 1MZ PERFORMANCE/STOCK STUFF FOR SALE! HERE!
ekopel is offline   Reply With Quote
Old 12-02-2008, 11:19 PM   #2 (permalink)
Dude Wheres My Car?
nukem678's Avatar
View nukem678's Photo Gallery
Have you tried an impact wrench? See if you can get the biggest one possible. They have electric ones too. Thats your best bet.
I lost my Camry in a parking lot once, Now it will never happen again
nukem678 is offline   Reply With Quote
Old 12-03-2008, 01:32 AM   #3 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $349353
View BMR's Photo Gallery
A shade tree mechanic's method I've read about, but never tried, is to use the starter to break it loose. Put a socket and breaker bar on the nut, brace it somehow in the engine bay, and give the starter a couple of pops.
Edit: Of course the ignition system needs to be disabled somehow. Ya don't want it starting up and have a breaker bar flailing around!
BMR is online now   Reply With Quote
Old 12-03-2008, 01:45 AM   #4 (permalink)
just a nobody
Try one of this with your breaker bar: http://www.amazon.com/dp/B0017I3E98?...0&linkCode=asn. It fits right into the cam gear to hold it in place.
How long of a breaker bar are you using? Anything shorter than a 24", you might want to put a pipe on it.
N.E.O.
Old 12-03-2008, 02:24 PM   #5 (permalink)
View kegunder's Photo Gallery
I've used the method BMR mentioned. The bar will hit the control arm near the front side. Put a towel or something to absorb the impact.
And one slight tweak of the starter is all that is needed. Don't let anyone watch it happen, stuff might fly off.
kegunder is offline   Reply With Quote
Old 12-03-2008, 05:07 PM   #6 (permalink)
Canyon Killer
I ended up pulling the two intake cams and then pulling the two exhaust cams with the seals and inner timing belt cover together lol. Not correct way to do it, but it worked, and I really don't need to take them apart for any reason. lol
Old 12-03-2008, 07:51 PM   #7 (permalink)
just a nobody
You were talking about the cam gears, right? Because, the others seem to be suggesting ways to take off the crank pulley.
Well, eventually you need to remove the gears to replace the cam seals, otherwise, you might take the chance of having leaking seals.
N.E.O.
Old 12-03-2008, 08:03 PM   #8 (permalink)
Canyon Killer
Yeah, good catch. Didn't even realize that. Well I am going to just get a whole new bottom end, so I wont have to pull off the crank pulley (thank god). but yeah, I obviously will have to remove the gears, but it will also be much easier since it is now out of the car. I much just use a vice, considering not even my 12" crescent wrench and a breaker bar can get it off.
Old 12-03-2008, 08:11 PM   #9 (permalink)
just a nobody
Now that it is out of the car, you can use an impact on them.
Depending on how the lower end comes, you still might have to pull some of the parts off from the old block. And it would actually be easier to pull the block if the crank pulley is off, give you a little more room to work with between the block and the frame rail.
N.E.O.
Old 12-03-2008, 08:17 PM   #10 (permalink)
Canyon Killer
IMO - I can barely fit a deep socket in between the motor and engine bay... If its a problem, then I will have to do the obvious, god I love TN and how helpful people are.
I am going to use the impact wrench for sure on those cam gears now that i think bout it.
Old 12-03-2008, 08:24 PM   #11 (permalink)
just a nobody
You will be surprised how much difference without the crank pulley makes. Keep us posted if you have any other questions, someone will bound to give you some suggestion.
Be careful with the impact wrench on the cam gear, you don't want to damage the cam, have someone keep a steady hold on all the parts.
N.E.O.
Old 01-01-2011, 07:50 PM   #12 (permalink)
View dudutzu's Photo Gallery
N.E.O.
I know this thread is really old but I'm thinking about replacing the camshaft seals soon and wanted to make sure I don't do anything stupid,
why not use the impact wrench on the cam gear? or you can use it as long as something is holding it from moving?
also I'm gonna replace the timing belt too, will the timing belt hold the cam gear enough to get the bolt loose or is gonna slip?
dudutzu is offline   Reply With Quote
Old 01-02-2011, 10:40 AM   #13 (permalink)
esvipron's Avatar
View esvipron's Photo Gallery
4th Generation
Just brace it around against the suspension, and if you have somebody to hold it—at the same time—from distance with a piece of 2x4 much better. It’ll work.
164K and running good.
esvipron is offline   Reply With Quote
