2000 Camry I4 CE - rear sway bar - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-02-2008, 05:07 PM   #1 (permalink)
HexNet
View Saltydog5's Photo Gallery
Anybody know the size of the rear sway bar for a 2000 Camry CE with the Fs-FE?
Also, am I right that I have to have the rear off the ground, but don't have to disconnect the end links to remove the sway bar bushings?
Thanks,
SD5
ps. I've searched the forums and have come up empty on this, so if it's there and I missed it, it wasn't because I wasn't trying
Saltydog5 is offline   Reply With Quote
Old 12-02-2008, 06:43 PM   #2 (permalink)
View toyomoho's Photo Gallery
A 16 and 17mm bushing diameter is listed.
Suggest to go under the car and measure, if you don't have a caliper measure the circumference. If using inches divide the circumference by 3.1415 to get the diameter. Then 1 inch = 25.4mm.
The bushings can be changed without removing the bar or links.
Old 12-07-2008, 08:03 PM   #3 (permalink)
HexNet
Thanks
TOYOMOHO,
Thanks for the info. I 'mic'd' it using a poor man's micrometer.... an adjustable wrench! Came out 16 on first measurement, 15 on second. Turns out it is a 16 and is MARKED ON THE SIDE OF THE RUBBER OF THE BUSHING! However, 15 is a better answer, as there was noticeable wear of the bar from the bushing.
This was probably the easiest job I've ever done. ~30 minutes! After suffering with the thumping most of the summer and fall... well just glad it's done. Now on to the wheel bearing on the Odyssey:-)
SD5
Old 01-04-2009, 09:54 AM   #4 (permalink)
View atoya's Photo Gallery
Originally Posted by Saltydog5 View Post
TOYOMOHO,
SD5
How did you replace it with the swaybar in place? do you get split bushings? any recommendations?
thanks
atoya is offline   Reply With Quote
Old 01-04-2009, 02:29 PM   #5 (permalink)
The bushing is split, retainer is held on by 2 bolts. Easy enough job unless the bolt treads are rusted on.
Old 01-05-2009, 01:21 PM   #6 (permalink)
HexNet
toyomoho nailed it
Yes, the bushing are split. I did hit the bolts with penetrating oil the day before and that seemed to help. In 20/20 hind sight I would have replaced two of the bolts; one on each side. One catches the road grime more than the other and was noticeably corroded (one both sides).. but probably not a real problem. Trouble is I'm a keep it for 10 yrs kind of guy:-)
