Timing belt, crank seal, water pump ?
Hello,
I have a 1999 Camry 4cyl 90k miles and i'm wondering if i can gamble and just have the timing belt replaced and maybe avoid replacing the crank seal as recommended by the dealer? In other words, does anyone know if the crank seal really typically needs to be replaced at 90k or could it hang in there alot longer if one is a light footed driver possibly?
Reason is there is a big difference in the cost from $250 to replace the belt up to $550 if they also replace the crank seal and $900 if they replace the water pump, but it looks like i may be able to replace the water pump myself cos it looks like it's external to the timing belt housing.
Thanks very much for any insights on these components!
BobK
