Thanks, you're right.
www.toyotapartscheap.com (in San Diego), the cluth disc, throwout bear., and pressure plate total up to $175. Not bad at all, the aftermarket one I was eyeing was 170...
I still have to posotively verify that it IS the rear main. If so, I'm thinking of waiting until about April. I have a garage which is full of cars, cold, and not well lighted.
The '91 Corolla I've built for my daughter is nearly done. I have KYB GR-2's to put in. A broken key-piece is stuck in the ignition, I think a locksmith can remove that. Last but not least the cam bearings were overtorqued. I just need to remove 1 bearing cap at a time and re-locktite the bolts this time using a torque-wrench. The car has a brandy-new shortblock in it...
I can drive that until spring I guess...
