Check Engine Light On Then Engine OFF
Car is 94 Camry V6 1mzfe auto. This is what happen in order.
1. First start of the day in any condition will not hold idle, I have to step on the gas for it to warm up then it idle fine. This is when the Check Engine Light is on.
2. It idle, but I can not rev pass 2000, when i step on the gas too hard, then engine bog down and stall. If I press the gas slowly, the RPM will rise with sputter to about 2000 rpm. This happen while CEL is on.
3. When I reset the ECM, the CEL is off, the engine start up and idle like nothing happening. But after about 5 minutes or less of idle, the CEL light up then the engine is shut off immediately.
4. I restart the engine, it start right up becuase right now the engine is already warm not like in step 1. It start back up with CEL on and can not rev pass 2000 rpm. It seem like the ECM is in Fail Safe MODE whenever the CEL is on.
This is what I had done but no help.
I change the VSV valves, take EGR out and clean it, change ECT sensor, Change fuel filter, new spark plugs, Seaform gas tank, oil, and intake. check MAP and IAC with Ohm meter and it is good according the camry manual. Also check front oxygen sensor and Camshaft sensor good. I bridged the two knock sensors' wires at ECM.
Only thing I suspect is both of my knock sensors are bad, that trigger the ECM to go into Safe MODE which make the engine can not rev past 2000 rpm.
What you guy think ?
