My driver side unlock button stopped working but the lock button still worked. Turned out that the cable in the door got cut.
Your gonna need to remove the door trim and the cover right next to the foor rest.
Inside the door just push the rubber protective thing into the door.
Inside the car, disconnect the harness for the wires that come from the door. Then push those wires into door as well.
Then its just a matter of removing the protective rubber thing, so you can inspect the wires.
also if your planning on installing after market speakers, right now is a good time
