What is my problem, struts or springs? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-08-2008, 02:29 PM   #1 (permalink)
mj8
View mj8's Photo Gallery
93 4 cylinder with 160k, when I hit a bump on the drivers side or passenger side the front wheel that just took the hit...just bounces away and takes what seems like 3 seconds or so to stop bouncing, fairly vigorous bouncing. The backs seem to be fine. My question is this....are my springs bad or just my struts? I thought about buying new struts and using my old springs but are the springs part of my problem? The car drives fairly smooth until I hit a spot in the road that isn't smooth.
mj8 is offline   Reply With Quote
Old 12-08-2008, 02:56 PM   #2 (permalink)
Andrew Liu's Avatar
View Andrew Liu's Photo Gallery
blown strut. good bet that your springs have sagged too, on a 15 year old car.
Personally, I would take this opportunity to get some new struts (kyb or tokico) and lowering springs.
Andrew Liu is offline   Reply With Quote
Old 12-08-2008, 02:57 PM   #3 (permalink)
'_'
Touge Star
'_''s Avatar
Gameroom cash: $421512
iTrader Score: 10 reviews
View '_''s Photo Gallery
Someone can correct me if I'm wrong, but I believe you need new struts. The struts control the bounce. If they're worn out/old, the car will tend to bounce a lot over bumps.
山道だいすきです。
http://www.cardomain.com/ride/2538603
'_' is offline   Reply With Quote
Old 12-08-2008, 03:13 PM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
blown strut...worn springs. struts are the key problem but the springs arent helping.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 12-08-2008, 04:58 PM   #5 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
blown struts definitely
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 12-08-2008, 10:13 PM   #6 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
As other said, struts. But depending how long it;s been like this, you may have damaged other parts of the suspension too.
5 Lug Corolla WHAT?
Old 12-08-2008, 11:20 PM   #7 (permalink)
toyota = cool
tacomonkey69's Avatar
View tacomonkey69's Photo Gallery
i vote tokico
1997 Toyota Camry V6 5-Speed
1995 Lexus SC400...big plans for this one
tacomonkey69 is offline   Reply With Quote
Old 12-09-2008, 12:29 AM   #8 (permalink)
cruisn76's Avatar
View cruisn76's Photo Gallery
vote for KYB if you want to restore back to factory ride
92 Camry 4 cyl 5 Spd
390,000km, Retrofited Projectors + 6000k HID, 2500k Fogs, SRI, K-Sport Coilovers, TRD Rear Sway Bar, GEN4 Ralco Short Shifter, Alpine 7" IVA-D900, 2 x 10" MTX / MTX 900W Amp
cruisn76 is offline   Reply With Quote
Old 12-09-2008, 08:57 AM   #9 (permalink)
Heat's Avatar
View Heat's Photo Gallery
Just for the sake of throwing out a ballpark price, my mother paid $900 to have all of the struts replaced and two CV joint boots replaced on her (now my) '95 Camry LE.
Heat is offline   Reply With Quote
Old 12-31-2008, 11:00 AM   #10 (permalink)
mj8
I would really like to prevent from replacing my springs....I don't care if this car handles like a dream or not I just want it to be safe and stop the vigorous shaking/bouncing when I hit a bump. Should I replace the strut mounts as well, is this a wear item?
Old 12-31-2008, 11:08 AM   #11 (permalink)
If the mounts have 160k miles on them, replace them too. They do break with age.
5 Lug Corolla WHAT?
Old 12-31-2008, 12:52 PM   #12 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $908127
iTrader Score: 59 reviews
Originally Posted by tacomonkey69 View Post
i vote tokico
I've used both..go with tokico struts.
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 12-31-2008, 01:10 PM   #13 (permalink)
mj8
does the manufacturer matter or can I just get whatever? is there a bearing in there or is just a metal plate with a rubber insert?
Old 12-31-2008, 01:45 PM   #14 (permalink)
Venom_5's Avatar
OEM Toyota Mounts, or KYB Mounts (like from TireRack) are best ... people have had problem with cheaper, and other aftermarket brands
Old 12-31-2008, 02:48 PM   #15 (permalink)
^ Yup, exactly.
I always go OEM Toyota as I get employee pricing at my local dealer, which I doubt you do. So I'd go KYB. They SHOULD come with the bearings (Toyota is seperate).
Your best bet is to convert to the 95-96 suspension setup if your doing the work yourself. It's a 1 piece strut as opposed to the 92-93 Seviceable struts, where you need to take the strut out of the housing.
5 Lug Corolla WHAT?
