200 Camry Ignition Cylinder
I meant 2000 Camry Ignition Cylinder sorry!
I need to replace my driver's side door lock cylinder and the ignition cylinder. I took the car to a lock smith who looked at it and is of the opinion that the pins are worn just like the key or bent. A new toyota key also did not help. The ignition sticks alot of the time and the driver door is hard to get the key to turn sometimes now. That being said has anyone had experience in replacing the ignition cylinder? The repair manual I have says to remove the steering wheel, but I'm not sure I understand why that needs to be done? The overall repair itself doesn't look complicated just trying to see if anyone else has done this before.
Reason: Wrong Subject
