anti freeze leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-10-2008, 01:18 PM   #1 (permalink)
View kidxrobot's Photo Gallery
anti freeze leak
so i jus noticed my anti freeze is leaking. i filled it up 2 days ago now its bone dry but my car isnt over heating the needle only goes to tha halfway point u guys got any clue wuts happenin?
kidxrobot is offline   Reply With Quote
Old 12-10-2008, 04:24 PM   #2 (permalink)
View toyomoho's Photo Gallery
The upper and lower radiator tanks are plastic, Inspect the tanks for cracking and leaks. Look down beteen the radiator and engine at the plastic air shield for signs of coolant.
With engine cold run your hand over all the coolant hoses for signs of coolant. Be sure to check the bypass hose which can be buried and hard to see.
Check the area under the timing cover for signs of coolant leaking from the water pump.
