Moonfroof stuck! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-12-2008, 09:20 AM   #1 (permalink)
View Brooklynite330's Photo Gallery
Moonfroof stuck!
Hi guys, I'm a new member here.
My 2001 Camry moonroof is stuck open and it won't close. It isn't the fuse because my windows still work. There is no sound when i pressed the buttom to open or close. What could be the problem? More importantly, is there a way I can close manually? or any other ways is open to suggestion.
I haven't had the time to bring it to a mechanic since I am a college student away from home.
Thanks in advance
Brooklynite330 is offline   Reply With Quote
Old 12-12-2008, 12:21 PM   #2 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
I know on my 96 Camry you can manually close it, and I think it;s the same way on yours. If you take the cover off the controls, there should be a round thing with a notch, which you use a flathead screwdriver for to close manually.
As for why it isn't working, if you say it;s not the fuse, and there is no noise at all, I'd think either the motor died, ot the butten is bad.
5 Lug Corolla WHAT?
