Just made a pretty good cheap intake. :-D - Toyota Nation Forum : Toyota Car and Truck Forums
Closed Thread
Old 12-13-2008, 12:55 AM   #1 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
All in all, cost me about $70. I just bought a different bend for the filter, so it will point right to the tube, and I still need to buy the adapter for the tube to filter.
5 Lug Corolla WHAT?
ASG14 is offline
Old 12-13-2008, 01:05 AM   #2 (permalink)
View Albuynp Ryeno's Photo Gallery
Unless you somehow put an enclosure around that air filter and connect it to that tubbing. The air will get sucked up from the engine bay. Essentially that tubing useless.
1995 Camry V6 LE - Sold
1998 Camry LE
1992 SC300 5SPD
1992 SC400
Albuynp Ryeno is offline
Old 12-13-2008, 01:09 AM   #3 (permalink)
^ Um, wha? The point of funel and the tubing is to RAM more air into the filter at higher speeds.
5 Lug Corolla WHAT?
ASG14 is offline
Old 12-13-2008, 02:38 AM   #4 (permalink)
Toxygene's Avatar
View Toxygene's Photo Gallery
LMAO Bwahahahahah.....
Ok I needed that.
If you put the filter on the end of that ribbed hose and actually connected it to the tubing you have extended from your supercharger... you still wouldn't have a ram air effect. You'd have a Cold Air Intake. It would be better but not what you are calling it.
If you wanted it to be a true RAM air effect then you'd have to cut that bumper grill out of the way, mount the filter pointing directly at the opening you would have just made in the bumper, and have smooth tubing going all the way to the supercharger. Which by essence of the fact that you have a supercharger is not really going to make that much of a difference. Getting a cooler air charge would be a better idea though than sucking air from within the engine bay. Don't think that because you put a little ribbed hose starting from behind a BLOCKED area of the bumper and route it to the GENERAL vicinity of the air filter that all of a sudden you made a RAM AIR intake. The air filter will suck air equally from all 360 degrees around it. That includes the HOT air being generated by the engine, supercharger, transmission, battery (yes they get hot too), and the best one of all for a true HOT RAM AIR effect is the RADIATOR WITH FANS ON IT TO BLOW HOT AIR TOWARDS your tiny little hose. Yeah, now logically lets think about that little bit of air coming from your ribbed hose and if it has a chance to overpower all of that hot air. It's not going to happen nor is the air filter selectively going to only suck air from that hose.
For the sake of trying to help out, you'd be better off replacing your filter with something like this from PRM Racing http://www.prmracing.com/cold-air-in...stom-shop.html
That way the filter would be self contained and sheilded from the hot air in your engine bay and you could then attach the tubing to the end of it and make at least a true cold air system. If you wanted to make it more effectual then that, then try looking up some automotive air ducting like this: http://www.stockcarproducts.com/brkduct.htm
Attach that to the back of the bumper behind the grill and then attach your flexible tubing to that with the PRM filter connected to that with your metal tubing leading to the supercharger. That would be as close as you could get to a ram air/cold air filter and minimally not having to change much.
Toxygene is offline
Old 12-13-2008, 06:45 AM   #5 (permalink)
^^^^agreed
1998 Camry LE
1992 SC300 5SPD
1992 SC400
Old 12-13-2008, 07:36 AM   #6 (permalink)
engineer in training
Gameroom cash: $145055
OMG haha, you almost got me with that man sarcasm early in the morning evades me I was actually thinking up some jackass reply then I remembered what 99% of your posts are, so I was like wait a minute... Im missing something.. Oh there it is yup I see what you did there.
Luckynumber5 is offline
Old 12-13-2008, 07:57 AM   #7 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
pretty cool adam.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
bigbird is offline
Old 12-13-2008, 06:18 PM   #8 (permalink)
4th Gen Camry Owner
View kpszar's Photo Gallery
Well, I took off my ram air and basically did the same thing. But now I am moving to some exhaust or intercooler piping left overs:P
kpszar is offline
Old 12-14-2008, 05:53 AM   #9 (permalink)
If you don't have a supercharger there is really no point unless you just want to tackle the project.
Adam have you looked into a colder thermostat yet? With a roots blower it's one of the best things you can do! First mod on most of the Grand Prix guys list.
Old 12-14-2008, 08:39 PM   #10 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
1) ADAM finally, your making noise
2) Engines dont suck in air, its due to a lower pressure inside the cylinder that causes the outside air to be forced into the cylinder, its called pressure differential...Look it up
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline
Old 12-15-2008, 01:10 AM   #11 (permalink)
Toxygene's Avatar
Oh, I'm sorry, I didn't realize I was talking to anyone with an engineering degree. How embarrassing. Shall I word all my posts henceforth in overcomplicated engineering jargon? I should state however, that I'm entirely comfortable the size of my ego and feel no need to over inflate it with jargon that would insinuate otherwise as you have.
Let me be so kind as to ask you kindly if I may please use normal words so as to not look like an ass. I really don't feel the need at this time.
Thank you kindly for your consideration.
90 Celica Alltrac Turbo ; 02 Celica GT ; 06 Audi A3
Toxygene is offline
Old 12-15-2008, 01:18 AM   #12 (permalink)
^ People like you are the reason no one makes jack shit for the Camry's.
5 Lug Corolla WHAT?
ASG14 is offline
Old 12-15-2008, 04:31 AM   #13 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $908127
iTrader Score: 59 reviews
Nice Adam.
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
eyeball96 is online now
Old 12-15-2008, 10:26 AM   #14 (permalink)
This thread is outstanding.
Old 12-15-2008, 08:24 PM   #15 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $248601
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
the intake looks good but that final bend is too sharp you need less of an angle to make it work more effectively(sp?)
oh btw no bashing please...
there is no "plug and play" for camrys just "plug shit it doesn't fit cut shave rewire weld hit it with a hammer...buy a new one have more patience then play"
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline
Closed Thread
