95 Camry Neutral Safety S
95 Camry 5s 4-cyl Auto
I have been having quite a difficulty adjusting the switch. Issues are intermittent no start in park, shift to neutral and it will always start, no reverse lights and no reverse light on dash. I can usually get the R on the dash and the reverse lights to come on if i move the shifter ever-so-slightly out of reverse. Hence why I was readjusting it.
Anyway, I've readjusted it as best as I could but I suspect theres corrosion internal to this switch and I'd just as soon not spend $300ish on a new one. Has anyone taken one apart and cleaned up the contacts? Doesn't look like it can be disassemebled, just figured I'd ask.
The procedure I used (correct me If I made a mistake please) was placing the shifter into neutral, loosening the two NSS retaining bolts a bit and aligning the index tabs as closely as possible, then tightening said bolts. Sound good?
Edit: On the above procedure, is there any error of margin for the index tab alignment?
