Originally Posted by Quattrovalvole
Thanks to all for the answers
So I don´t need to remove the heads.
My mechanic tells me that I need several other parts, since I need to remove the heads to make it.
So if I need to remove the heads, What else would I need in addition to the valve seals and the head gaskets?
He is asking me to get the set of decarbonization to make the job. Does someones knows if this exists?
QV
Go find another mechanic that can do it with the heads on. Like people have already mentioned, they're are known techniques out there to do it with the heads on. An experienced mechanic will have done this I'm sure, or at least find one that is not going to charge you book value for the job which probably is based on head removal. Once you start taking the heads off, the parts and labor go way up since you need new gaskets, etc. Decarbonization is basically cleaning the combustion chamber as far as I know. This is not necessary but advisable if you remove the heads.
BTW Luckynumber5, I watched the video of that valve tool. Very impressive. I bookmarked that for future jobs. Definitely the tool to get.
dave mc
