Radio issue with 94 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-14-2008, 02:01 PM   #1 (permalink)
View mcca0539's Photo Gallery
So yesterday my car wouldn't start. The battery was dead, reason behind this being that for some reason the headlights did not automatically turn off when I opened the door (after car was off) like it was supposed to. Unfortunately it was in the middle of the day so I did not realize that they were still on.
So when I went to turn the car on (4hrs later) absolutely nothing happened, but when I removed my key there was a clicking sound from the fuze box located behind the change holder (atleast thats what I use it for), down on the bottom left side of the dash. After some investigating I realized the headlight switch was turned on, so i turned that off and the clicking sound stopped.
I got a my car jumped and went to get a new battery (the battery needed to be replaced anyways), however ever since the battery died, the radio no longer turns on (aftermarket JVC) absolutely nothing happens. I thought it might be a fuse, but the dash lights all still turn on, and I thought they were on the same fuse.
Any help would be greatly appreciated!!
Thanks.
mcca0539 is offline   Reply With Quote
Old 12-14-2008, 02:07 PM   #2 (permalink)
TheKevin's Avatar
iTrader Score: 6 reviews
View TheKevin's Photo Gallery
its a different fuse. my friend had something like that happen to his car
TheKevin is offline   Reply With Quote
Old 12-14-2008, 02:08 PM   #3 (permalink)
just a nobody
Aftermarket system can or may have hooked up differently then the factory system, or there maybe some type of security code. Call or check online for information on your particular model to see if that is the case.
Check the door jamb switch for your head light problem.
N.E.O.
Old 12-14-2008, 04:34 PM   #4 (permalink)
View tran.man48's Photo Gallery
sometimes aftermarket head units have a fuse built into the back. I'd check that.
Like N.E.O. said, you should probably clean your door switch. They get corroded and don't do their job well anymore... There's a DIY on here, it's a pretty simple 10-minute job.
Originally Posted by Zembonez View Post
Nothing is impossible with enough money and beer.
tran.man48 is offline   Reply With Quote
Old 12-15-2008, 01:14 AM   #5 (permalink)
Proud Toyota Owner
CamryWilly's Avatar
View CamryWilly's Photo Gallery
Went to see those gen6 camry's at the dealer just for fun... And guess what, there still using the same door switch!!!
Guess there stuck with a warehouse full of these cr***py switches!!!!
CamryWilly is offline   Reply With Quote
