Shaking car, reduced acceleration, WTF? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-16-2008, 06:28 AM   #1 (permalink)
View pdilla's Photo Gallery
3rd Generation Shaking car, reduced acceleration, WTF?
My LE L4 used to have a weird hiccup going on. While in idle, the car would sort of "bump" as if I had huge subwoofers or something. I would compensate by shifting to neutral at red lights.... but NOW, it's bumping and shaking all over, not only through the steering wheel.... but the whole car.
And on top of that, it feels like I'm towing a TRAILER or something. I can't accelerate very well up hills anymore. On the freeway, unless I'm going downhill, I can't pass 60.... even if I floor it.
And speaking of the throttle, while I am accelerating, I hear a sort of high pitched buzzy thing going on.
I also have had recent trouble cold starting, it doesn't happen all the time, but I need to rev the engine a bit after it turns over in order for the car to stay on. Although its probably just a dirty IAC...
Suggestions?
pdilla is offline   Reply With Quote
Old 12-16-2008, 06:38 AM   #2 (permalink)
Love Machine
plbill's Avatar
View plbill's Photo Gallery
Same problem with mine. Bad idle,and hesitation during acceleration. Help would be appreciate.
Camry 1992 2.2 LE
plbill is offline   Reply With Quote
Old 12-16-2008, 06:49 AM   #3 (permalink)
Just to add... It seems to shake much worse when I shift to reverse.
Old 12-16-2008, 09:25 AM   #4 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $303505
View MrSo0h0o's Photo Gallery
I would clean out your throttle body and see if that makes a difference. Also, try using seafoam through one of your vacuum hoses(do a search on it if you dont know what this is).
MrSo0h0o is offline   Reply With Quote
Old 12-16-2008, 12:51 PM   #5 (permalink)
View imbest123's Photo Gallery
exactly what i would recommend and a probably cause of the problem could be a faulty idle air control valve
Bolt ons are so yesterday
imbest123 is offline   Reply With Quote
Old 12-16-2008, 02:43 PM   #6 (permalink)
Proud Camry owner.
Loganwiththe'93's Avatar
View Loganwiththe'93's Photo Gallery
The only issue my car has that is related to this is that high-pitch buzz. Sounds kind of like the buzz in your ear, or a bit like a computer monitor going bad.
1993 Toyota Camry LE 4 Cylinder
Running 100%
Loganwiththe'93 is offline   Reply With Quote
Old 12-24-2008, 09:25 PM   #7 (permalink)
Ok, so I cleaned the throttle body out, now I have RIDICULOUSLY high RPM in idle. Like around 3100.
Scaring the shit outta me. Now what???
Old 12-25-2008, 01:37 PM   #8 (permalink)
Gameroom cash: $303255
Check for vauum leaks. Make sure if you disconnected any vacuum lines that they have been reattached. Also, be sure to inspect the large tube leading to the throttle body that you had to remove in order to clean it. They can crack with age and cause this problem.
Mike
Old 12-25-2008, 10:15 PM   #9 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
View JCamry94's Photo Gallery
3rd Generation
Check for leaks, check your throttle kick back cable, may have tightened or loosened something on accident, reset the battery, check your spark plugs/wires as well.
ACCIDENT...
Help me bring 'er back to life!!!
BUY MY STUFF: http://www.toyotanation.com/forum/66...e-all-obo.html
Thanks
JCamry94 is offline   Reply With Quote
Old 01-23-2009, 05:03 AM   #10 (permalink)
3rd Generation Sorry about the long wait...
Anyways.... I fixed that high rpm problem, I put Seamfoam up the vacuum hose, enjoyed the smoke show, and now I got no more hesitation during acceleration, ALTHOUGH.......
The shaking still persists. When I turn my car on, I go around the back and find that the exhaust pipe is pushing air out in "putts".
It goes like, " putt-putt-putt-putt-putt" instead of the smooth airflow that normally happens. So there's where the shaking is coming from.... now what???v
Old 01-23-2009, 11:51 AM   #11 (permalink)
It sounds like you have a classic case of missfiring, especially under load. That is usually caused by faulty ignition system components. I would check/replace spark plugs, spark plug wires, distributor cap and rotor. If that doesn't solve the problem, I would check the fuel injectors. You may have 1 bad injector.
Mike
Old 01-23-2009, 02:23 PM   #12 (permalink)
View hooRAH's Photo Gallery
Mike
Beat me to it. The thumping definitely sounds like a misfire.
Due to the fact that the Camry uses a map sensor rather than a MAF (I think), any vaccum leak will be noticed by the map sensor and compensated for, and your idle will increase, whereas on a car with a MAF sensor, the mixture would be all wrong and could cause misfires.
Whenever a car is misfiring, the FIRST thing I would check are the spark plug wires. When replacing the VC gasket on our camry, I tore one of the boots on the wire. Had a pretty bad misfire until I replaced the cables.
With the car in a dark area (NOT in the garage with the door closed), start the car and look for blue arcs.
Next, I would check the spark plugs. After that, I'd start checking out the ignition coils and try to see if there are any pending codes in the OBDII system.
01 BMW 330Ci - 5spd / 93 BMW 525i 5spd-SOLD/ 98 Camry LE
hooRAH is offline   Reply With Quote
Old 01-28-2009, 07:43 AM   #13 (permalink)
Toyota n00b
View VTHokiEE's Photo Gallery
3rd Generation Same thing here
I have the same putt-putt thing going on in my Camry (1993 XLE V6, AT). Acceleration sucks and shifting has gotten rougher. Sometimes I have to back off slightly on the gas and then things shift right away. But back to the shaking...
I have cleaned the TB, replaced spark plug wires, distributer cap and rotor (been trolling the forums on this problem a while). PCV is ok, the plate that replaces the MAF in this car (name is escaping me) passes all the resistence checks that Haynes manual suggests. I have run some injector cleaner in the gas a couple times, no difference.
So, in addition to suggestions for the above, what should the car idle at in drive? Neutral? Right now it is about 1200-1400 in P/N and drops to ~800 in D/R.
VTHokiEE is offline   Reply With Quote
Old 01-28-2009, 07:56 AM   #14 (permalink)
Toyota n00b
3rd Generation
I forgot to add that the gas mileage is also sucking and the car occasionally surges some while driving and then goes back to its underpowered ways. The shaking is much worse while accelerating (or trying to) than it is when coasting or just maintaining speed.
As a side bar, I didn't see a DIY on replacing distributer cap and rotor. I took pictures while I was doing it, so I can try to gen one up if it would help folks.
Old 01-28-2009, 02:10 PM   #15 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
iTrader Score: 10 reviews
View ECale3's Photo Gallery
The worst part of dying is being alive.
ECale3 is offline   Reply With Quote
