The EVAP circuit meaning all parts, hoses, wiring within that circuit.
This circuit could include vacuum hoses, sensors, charcoal cannister, even the gas cap. There are a couple of elelctric solenoid valves to open/close vacuum hoses, a pressue sensor to monitor fuel tank and system pressure but no serious electronic circuits like a computer board, etc.
The codes attempt to narrow down the area but is are not part specific..
P0446: Evaporation Emission Control System Vent Control Malfunction.
The computer is detecting one of the below:
When the VSV for the vapor pressure sensor is off there is no continuity between the vapor pressure sensor and charcoal canister.
When the VSV for vapor pressure sensor is on there is no continuity between the vapor pressure sensor and gas tank.
Continuity means air flow. The various parts are connected with hoses.
Once the EVAP system has been purged the pressure in the canister is equal to the atmospheric pressure (the system has a leak). Hence the need for a very simple pressure sensor.
Items to check are a malfunctioning VSV valve (solenoid valve) for either the vapor pressure sensor or EVAP valve (another solenoid) and their wiring, bad vapor pressure sensor (same sensor as before), damaged or disconnected hoses, cracked canister, fuel tank overflow valve damaged (manual valve).
Suggest starting out by checking the vapor pressure VSV, this is the vacuum valve on the canister and the canister itself.
Overfilling the tank may lead to issues with the canister failing due to fuel.
Autozone may have the specific codes. Do a Google search on the code numbers plus the word Toyota. You should turn up a lot of interesting info and maybe a few drawings, etc.
