PO401 Code - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-16-2008, 11:02 PM   #1 (permalink)
Gameroom cash: $811387
iTrader Score: 10 reviews
PO401 Code
97 Camry CE 4-cyl manual with a PO401(I think) code. Scan tool said "EGR valve insufficient flow".
I checked all the vacuum lines, all are hooked up and clean. The EGR valve itself is clean and working properly. Where the EGR valve goes into the plenum is clean too.
What else should I be looking for?
Chris Crash is offline   Reply With Quote
Old 12-17-2008, 12:45 AM   #2 (permalink)
just a nobody
EGR VSV underneath the intake. Are you sure that you are getting vacuum to the EGR valve when it is supposed to?
N.E.O.
Old 12-17-2008, 12:46 AM   #3 (permalink)
View toyomoho's Photo Gallery
Have you checked the VSV valve that controls the EGR valve.
Old 12-17-2008, 06:48 AM   #4 (permalink)
View darican305's Photo Gallery
i had this same code for a year and i finally got it fixed and with my luck it was an under 100 dollar fix. what did was go to autozone and i bought the vaccum modulater and i bought 4 feet of new vaccum lines installed everything reset the check light and wala its been 2months and code free. give it a shot you can always return it if it dont work.
darican305 is offline   Reply With Quote
Old 12-17-2008, 10:06 AM   #5 (permalink)
N.E.O.
How would I check this?
Old 12-17-2008, 10:06 AM   #6 (permalink)
Where is the VSV valve and how do I check it?
Old 12-17-2008, 10:25 AM   #7 (permalink)
just a nobody
After the engine is warmed up, just pull the vacuum hose off at the EGR valve and check for vaccum there while revving the engine up. Download a copy of of the FSM, page 42: http://camrystuff.com/manuals/Gen4/SFI.pdf
The VSV is bolted on the engine underneath the intake manifold.
N.E.O.
Old 12-17-2008, 10:59 AM   #8 (permalink)
Do you mean the vacuum hose that goes right to the bottom of the EGR? It's a pretty big one held on with a flange and two bolts?
Old 12-17-2008, 11:04 AM   #9 (permalink)
To get to the VSV, would it be easier to put the car on a lift and get it from below or take the intake off?
Old 12-17-2008, 11:14 AM   #10 (permalink)
just a nobody
No, the small rubber hose that goes to the top of the EGR valve.
It is indeed a little easier to get to the VSV when the car is on a hoist, that is if that is the problem. It was just a suggestion that the VSV maybe the problem, you still need to test the circuit to verify first.
N.E.O.
Old 12-18-2008, 11:29 AM   #11 (permalink)
Alright. Thanks for your advice. I'll check the vacuum today and tomorrow I'll rip the VSV off and check it out.
Thanks a lot.
Old 12-18-2008, 12:04 PM   #12 (permalink)
View Sparkey's Photo Gallery
i am having this same p0401 issue and the car is running just fine. is there a way i can tell if it is the VSV or the modulator or is that just a trial and error situation? ive already lost $200 when it failed inspection and the asshole told me he was POSITIVE the EGR itself was the trouble....a week later here i am with the same issue.
Sparkey is offline   Reply With Quote
Old 12-18-2008, 12:13 PM   #13 (permalink)
What year and engine type?
Old 12-18-2008, 01:57 PM   #14 (permalink)
2001 4banger (2.2L i think)
*if i have the car running and rev it up i get vacuum at the EGR but the EGR shifts only for about 1second. is there maybe not enough vacuum to maintain its shifted state?
Old 12-18-2008, 05:57 PM   #15 (permalink)
We essentially have the same engine and problem, so I would just check all the things that were previously stated.
