98 Camry 250K miles cuts out - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-18-2008, 10:57 AM   #1 (permalink)
View charlie98camry's Photo Gallery
4 cyl, auto.
When stopped sometimes the car will almost die. have to keep foot on gas.
Been going on for months. It's worse if the fan is on, heat or air. I can turn the fan off and most of the time problem stops. And sometimes the fan is never on. It seems like it's running rough when on hwy but not sure. Replaced plugs and wires, valve cover gasket and fuel filter (non toyota parts if that makes a difference). Anybody have a clue, Thanks...
charlie98camry is offline   Reply With Quote
Old 12-18-2008, 03:41 PM   #2 (permalink)
View desi's Photo Gallery
Is your Car battery Dying?
How about replacing Distributor Cap and Rotor?
or IAC
Just throwing some ideas there.
If you find the Solution Please post it here.
desi is offline   Reply With Quote
Old 12-18-2008, 04:10 PM   #3 (permalink)
reply to desi
The battery is new but the positive will not stay tight on the post and the car wont crank and the alarm goes off.
It's an electronic ignition, don't think it has a D-cap & rotor. Do not know what
a IAC is.
Thanks for the info.
Old 12-18-2008, 06:09 PM   #4 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862710
View BamZipPow's Photo Gallery
Probably the obvious...replace the positive clamp.
BamZipPow is online now   Reply With Quote
Old 12-18-2008, 06:20 PM   #5 (permalink)
View toyomoho's Photo Gallery
If the idle it too low or rough but the car otherwise runs OK might clean the IAC valve. This valve controls idle speed.
Do a TN search on IAC valve to get an idea of what is about.
