Back fire through intake or exhaust?
Try
www.autozone.com for wiring diagrams. The site has a very good repair section for cars.
There is a Circuit Opening Relay that closes if the engine is being cranked over then stays closed if it receives a voltage from the computer that the engine is running. This would be the safety relay for the pump.
This relay is located behind the glove box.
You can bypass all the relays to power the pump. Find a small box inside the engine compartment labeled "Diagnostic" typically on the passengers or drivers shock tower mount. Inside the box are electrical terminals, jump the FP and B+ with wire then turn on ign key. The underside of the lid has the key.
For pump access remove the rear seat lower cushion. Pull up at the front side of the cushion. There is a steel cover behind the drivers seat that will be obvious. Remove this cover to access the top of the fuel tank and expose the access cover to the pump. The pump and fuel sender are connected to this cover and comes out as a unit.
