Motor dies temporarily at speed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2008, 04:54 PM   #1 (permalink)
View Raffky's Photo Gallery
Australia Motor dies temporarily at speed
I have just replaced head gaskets on my 3vzfe 260k. Initially, the motor would start for a few secs then die. I had a new MAF installed which fixed that prob. Now the motor starts and runs well but when driving on highway, it dies for a few seconds, then keeps running. This might happen every minute or so. It seems to happen more when you back off slightly with the accelerator. Any tips appreciated.
Raffky is offline   Reply With Quote
Old 12-20-2008, 05:05 PM   #2 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Any check engine light?
5 Lug Corolla WHAT?
Old 12-20-2008, 05:39 PM   #3 (permalink)
no engine light, no error codes.
Old 12-20-2008, 05:45 PM   #4 (permalink)
What do you mean by it "dies"? If it dies, it won't automatically start, you have to turn the key again or pop the clutch.
5 Lug Corolla WHAT?
Old 12-20-2008, 07:34 PM   #5 (permalink)
Revs drop by 500 or so for one or two secs then it goes back to normal speed. No restart or clutch needed
Old 12-20-2008, 07:35 PM   #6 (permalink)
Does this happen when accelerating, cruising, or slowing down (foot taken off gas)?
5 Lug Corolla WHAT?
Old 12-20-2008, 08:13 PM   #7 (permalink)
It happens most easily de-accelerating, also happens when cruising but does not happen when accelerating.
Old 12-20-2008, 09:13 PM   #8 (permalink)
What is the RPM's at idle, when the car is up to temp? I'm almost guessing this is a throttle body butterflt or IAC valve issue. Either the throttle body closing too much, stopping the air, or the IAC (Idle Air Control valve) went bad and not working.
5 Lug Corolla WHAT?
Old 12-21-2008, 01:58 AM   #9 (permalink)
The idle RPM at operating temp is normal. Whole motor operation is fine except brief rev drops when driving, as I mentioned. I will take a look at the throttle body and IAC valve as you suggest. I really appreciate your time and help!
Old 12-21-2008, 02:08 AM   #10 (permalink)
just a nobody
Check the TPS adjustment, it may have gone into close throttle fuel-cut. Maybe?
N.E.O.
Old 12-21-2008, 04:21 AM   #11 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Tranmission may not be shifting into overdrive, but does so once in a while, hence the rpm drop. Make sure you are in OD or not when rpm drop happens. If you switch off the OD and there is no increase in rpm then look to the solenoids in trans.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 12-21-2008, 05:19 PM   #12 (permalink)
Originally Posted by Stillrunning View Post
Tranmission may not be shifting into overdrive.
Your idea sounded promising but after a test drive, I found OD on or off did not make any difference. Engine still does the cut out. I will check into IAC and throttle. Damn annoying because it runs so well at idle and hard acceleration. After three weekends of heads removal work, I was dreaming of one of those instant, smooth start ups. At least I can drive it to work. Just have to persist and crack this prob.
